How to connect coils
Postby windgat on Tue Jul 22, 2008 8:32 am
There are two ways to connect the coils of a three phase generator: star and delta. I have found star to be the best.
Firstly, all coils in a single phase are connected in series. In the design on this site, that means 3 sets of 3 coils each. The coils in each phase are evenly spaced around the stator, and each coils must have exactly the same number of turns.
If you number the phases 1,2 and 3, and label the start of each phase 's', and the end 'e', then connect as follows:
- Connect 1s,2s and 3s to each other
- Connect 1e,2e and 3e to 3 of the the AC inputs of two bridge rectifiers (one AC connection is left unused)
- Connect the two + (positive) tabs of the two rectifiers to each other
- Connect the two - (negative) tabs of the two rectifiers to each other
It doesn't matter which side of the phase is the start or the end - just be consistent. Each phase must be connected up exactly the same way.
Re: How to connect coils
Postby Stefan on Sat Aug 16, 2008 8:17 am
For those of you (like me) that have no idea what all this Star and Delta stuff is, here is a page that explains it quite nicely :D
http://www.reuk.co.uk/Star-Delta-Wiring-for-Alternators.htm
Stefan
Postby nigel cox on Thu Apr 01, 2010 9:52 pm
does anyone have any simple schematic diagram to show the delta and star windings please, having just written instuctions just doesnt explain it, thanks nigel
nigel cox
Postby windgat on Sat Apr 03, 2010 7:23 pm
Hi Nigel. Did you look at the link in the post above? That seems to cover it - let us know if that's still not clear.
Postby windgat on Sat Oct 23, 2010 10:50 am
Here is a diagram of how to connect the coils
Users browsing this forum: No registered users and 29 guests
