windgat wrote:What I can't figure out about the design you are following, is why does the mold need a top? Why not just pour in enough resin to hold the coils firmly, and never mind the top is not flat?
windgat wrote:When you say resin, is that polyester or epoxy resin? I wonder if given more time it would set? Maybe if you can heat it, e.g. by leaving in the sun.
as his design has the rotors on either side, so I suppose if the one side is not as flat as possible, the airgap need to be bigger or maybe difficult to adjust
windgat wrote:Looking good! Do you think its necessary to super glue the magnets down? Might they stay in place due to the magnetic force alone?
windgat wrote:Ok! Ummm.... is it my eyes or is that hole in the resin not quite in the centre? If not, the rotor is not going to be balanced, and may vibrate when spinning at speed...
Users browsing this forum: No registered users and 21 guests
