1.5m blades by Aeroenergy
Postby windgat on Thu Nov 05, 2009 6:04 pm
Well I have finally got around to using the template I had laser cut to make a hub for the 1.5m blades.
Hub of 1.5m blades
The two hub disks are 12mm marine ply, both sides coated with glass woven mat and epoxy. There is a cut-out in the outer disk to allow access to the mounting nuts.
1.5m blades mounted on hub
Holding this in my hands has made me realise a few things which need to change to support these blades in a Cape Town storm:
    The 12mm shaft is too small - I have bought 20mm bar to use instead, with matching bearings
    The 42mm pipe I use as a pole is too weak. I have bought some 50mm pipe to replace the 38mm pipe I used before for the mounting bracket
now this means i need to get some rotor disks cut with a larger centre hole for the larger bearings.
Watch this space!
PS: If a few people want blades of this size and order together, the manufacturer has said they are willing to make a special price.
Re: 1.5m blades by Aeroenergy
Postby windgat on Sat Feb 20, 2010 9:44 pm
Here is a rig to test mount the blades:
1.5m blades ready to mount
Bolting on the sandwich hub:
15.m blades: Bolting the hub on
And up and running!
1.5m blades: Spinning
Postby Boerseun459 on Sat Jun 12, 2010 1:31 pm
I never trusted the idea of a 12mm shaft from the beginning and therefor purchased pillow blocks that will take a 25mm shaft. Wouldn`t mind to get my hands on a set of those 1.5m blades...
NS: Can you recommend anyone up here in Gauteng that does laser cutting?
Boerseun459
Active member
Postby windgat on Mon Jun 14, 2010 2:40 pm
I have now had a bracket made with a 20mm shaft. It also has a larger round tube for the pole - 50mm. Don't know of a laser cutter up North, sorry.
Those blades were available for R8000 initially, but I think you may be able to get them a lot cheaper that. They perform really well... make Nico an offer and see what he says!
Postby Boerseun459 on Tue Jun 15, 2010 2:16 pm
Thanx Windgat
Just one, obvious stupid, question: who is Nico and how do I get in touch with him?
Boerseun459
Active member
Postby aeroenergy2 on Fri Jun 18, 2010 3:52 pm
Contact me using nicovanm(at)hotmail.com
Nico
aeroenergy2
Postby Boerseun459 on Sun Jun 20, 2010 6:14 pm
Thank you, Nico
I`ll email you when I`m ready for the blades.
Still busy with the generator itself.
Gawie
Boerseun459
Active member
R3900 for a set of 3 blades
Postby aeroenergy2 on Mon Oct 11, 2010 12:34 pm
Until the end of this year we are offering
a set of 3 blades for R3900 (incl VAT).
Please contact me or Windgat.
nicovanm (AT) hotmail (DOT) com
aeroenergy2
Postby windgat on Tue Oct 12, 2010 10:09 pm
These are great blades at a good price - very powerful, and well made. I can recommend them!
Postby aeroenergy3 on Thu Jun 13, 2013 8:48 am
Our business is closing down. All remaining 1.5m blades can be collected for free
In potchefstroom. I will wait a few days before taking them to the scrapyard.
You can contact me on 0790182747
Nico
aeroenergy3
Users browsing this forum: No registered users and 8 guests
