using trailer axle as generator
Postby noll farmer on Mon Jul 05, 2010 9:08 pm
Hi All
Sitting yesterday on the porch and sipping a sun downer. Looking at my flat tire on the farm wagon. Idea came up!!
Cut the axle in half. Plant it vertical in the ground. Lift up the hub. Remove the brake pads. Mill the brake pads down. Glue coils onto the milled down brake pads. Put the hub outer shell in the same milling machine and mill 50% down in the inside. Glue permanent magnets to the inside of the hub. Fit the hub back onto the stub axle.
Does this sound feasible????
Deon
noll farmer
Re: using trailer axle as generator
Postby Greystoke on Fri Jul 09, 2010 7:47 am
So what was in that sun downer ? Image
(but I actually think it could work Image)
Postby windgat on Sun Jul 11, 2010 8:34 pm
Hey Deon. Sounds feasible... maybe post a rough sketch of what you are imaging?
And enjoy the mampoer!
Postby mariasam180 on Wed Jul 24, 2013 9:24 am
I like it very much thanks for sharing this information with us…. :impatient:
maria
mariasam180
Users browsing this forum: No registered users and 10 guests
