PVC blades / arched plate airfoil
Postby windgat on Wed Nov 18, 2009 5:57 pm
Here is a table of profile info which can be used for PVC blades. Main thing is to get the optimal angle of attack.
Angles of attack for various profile types
Some things I find a bit fishy:
- it says 4 degrees for a NACA 4412 - I thought this was 6 degrees.
- also all the degree are integers, which seems a coincidence. Never 4.5 degrees for e.g.
Users browsing this forum: No registered users and 2 guests
