Magnet Alignment
Magnet Alignment
Postby Robert_Patterson on Mon Jan 14, 2008 10:00 pm
Wingdat-
At one point, you mentioned that getting the rotors to separate was difficult due to the attraction.
In your design, with dual rotors, are the magnets placed exactly opposite from each other (mirror image) and be aligned with the same polarity? If so, wouldn't there be a repulsion?
Robert_Patterson
Re: Magnet Alignment
Postby windgat on Tue Jan 15, 2008 11:38 am
Hi Robert. If the magnets are aligned to attract, this maximises the magnet flux between them. If they are set to repulse, the flux lines push against each other, and much less, or no current would be generated.
I drilled and tapped three 8mm holes into the outer (front) rotor recently, and now use three long 8mm bolts to control the rotors during assembly/disassembly.
Users browsing this forum: No registered users and 2 guests
